United Kingdom (change)
Best bad weather brakes
Hello,
I'm competing in Hel Van Kasterlee, 120km muddy MTB ride.
What are the best brakes, which ones don't fail for 120k ?
And they say u need to break the new breaks, heat them with braking when they are new.
How do I do this on flat roads ? Or can I heat them in a pan ?
Regards
by Roflpain Fri Oct 08, 2021
For the ride you are describing you might be best advised to use Sintered pads. You can get further details on the various compounds here:
https://www.discobrakes.com/?s=1&t=0&f=viewtopic.php?t=4384__a__amp;sid=fbe31d3f3df5eb5cf0d0701f7263d813&
With regards to the bedding in, please have a look at this article. It will give you some useful tips:
https://www.bikeradar.com/advice/workshop/how-to-bed-in-new-disc-brake-pads/
We hope that helps.
Regards,
Michael
DiscoBrakes Team
by Mikethebike Fri Oct 08, 2021
Thx, very helpfull.
One more small question where I struggle most times:
How to choose the correct brake pads?
I have sram groupset. But there are so many different options.
I think I have these ones:
https://www.discobrakes.com/?s=0&t=0&c=2&p=838
These are correct not ?
Have a look at our Disc Pad Identifier:
https://www.discobrakes.com/?s=1&t=0&f=viewtopic.php?t=4398__a__amp;
This should help you to find the right pads for your brake.
Regards,
Michael
DiscoBrakes Team
Specifications subject to change. © Copyright DiscoBrakes.Com Pte Ltd 1999-2024
