free travel on seatpost 300mm
i need to know the minimum insert of the 300mm 31,6 carbon ti seatpost
i want to know if that measure is 90 or 100mm
i need bout 200mm out of frame
in negative situation, i must choose the 350mm version
by eliflap     Sun Jul 26, 2009
is it 70 mm as i saw on :
http://info.carboncycles.cc/?s=1&t=0&f=viewtopic.php?t=63__a__amp;sid=243b2b7a9e2459673b401a6891d45eca& ????
Question Question
i saw the measure are referred to 27,2mm .
same insert for 31,6 x 300 ? 70mm ???
by eliflap     Mon Jul 27, 2009
I have been checking on this. So far I can confirm that on the 350mm seatposts the min insert is at 90mm ie CC-S0735, CC-S0835 and CC-S1035. When I have more info on the shorter posts I will let you know.
by support     Tue Jul 28, 2009
Code Min Insert mm
CC-S0525 60
CC-S0530 80
CC-S0535 90
CC-S0625 60
CC-S0630 80
CC-S0635 90
CC-S0725 82
CC-S0730 82
CC-S0735 90
CC-S0825 82
CC-S0830 83
CC-S0835 90
CC-S0925 82
CC-S0930 83
CC-S0935 90
CC-S1025 83
CC-S1030 83
CC-S1035 90
by support     Wed Jul 29, 2009
