suggestions to solve the following problem !!!
Post new topic   Reply to topic DiscoBrakes.Com Forum Index  →  DiscoBrakes.Com
spadekevin
PostPosted: Sat Jul 21, 2018 1:37 pm    Post subject: suggestions to solve the following problem !!! Reply with quote
I'm looking for some suggestions to solve the following problem please:
I have a new bike with disc brakes. The front brake seems to be touching something once every revolution. However, when I touch the brake lever the catching stops. It is almost as though the brake pads have some slack or play in the caliper and they are touching the rotor. As soon as the slack is taken up by touching, not pulling, the brake lever the noise stops. Can anyone relate to this and explain how to remove the 'slack' on the pads and hopefully resolve the problem?
Incidently, when I get off the bike and spin the wheel the noise is not present - I only get the noise when riding the bike?!!
Please help.
I didn't find the right solution from the internet.
References:
https://www.bikeradar.com/forums/viewtopic.php?t=13085250
Recycle Management Solution Video
Thank you.
PostPosted: Wed Aug 01, 2018 4:15 pm    Post subject: Reply with quote
Thanks for your message, but it is very difficult to tell from afar what the problem(s) might be.
We would suggest to go to your local bike shop and get your brake system checked out. It is most likely something fairly small to put right.
Mike
DiscoBrake Team
Post new topic   Reply to topic DiscoBrakes.Com Forum Index  →  DiscoBrakes.Com All times are GMT
