can you get a hold of 700c carbon rims?, i have a powertap sl 32spoked
that i would like to build onto a carbon rim. can you help?
by glass Tue Feb 27, ...
Yes we can get 700c carbon rims. Did you want full carbon or carbon-alloy matrix? It could take 4-8 weeks for delivery. 32 spokes is an odd number for lightweight 700c rims so I would need to check on this, but we can certainly do 20, 24 or 28. If the delivery time is OK with you, I can check into pricing & availability. See specs below.
Spec 2
Material: Carbon Alloy Matrix
Spoke holes: 20/24/28
Finish: 3K woven clear coating - Available in black or silver
Profile: 30mm
Weight: 480gm
by support Tue Feb 27, ...
I would prefer carbon with an alloy braking surface? & the power tap hub i
have is 32 holed
If you can give me a rough idea on price?
We can get carbon with an alloy braking surface & the price would be 199 UK Pounds per rim. There would be a further delay for 32 Holes. Pricing &
availability is subject to change at any time.
I'll send you a private message with details on how to make a purchase if you would like to do so.
