carbon fork
are the graphics red or orange, can't quite tell from picture
by no3swan     Fri Mar 2, ...
The decal colours are orange & silver & look gorgeous in real life.
by support     Fri Mar 2, ...
Hi, can I ask what diameter the carbon tubes are? I have some clampmon v-brake mounts and I was wondering, if I changed my mind about my brakes, whether I could bolt these on. Cheers
by gooooooo     Fri Mar 2, ...
The carbon tubes have a diameter of 34mm, but if you're likely to change you your mind over disc brakes check out the fork that has both disc & V brake mounts.
carbon fork
