Rider Weight limits and carbon forks
jambonsambo
PostPosted: Thu Feb 27, 2020 11:48 pm    Post subject: Rider Weight limits and carbon forks Reply with quote
Hi ,
I weigh around 95kg , then with gear maybe 98 or so.
What are the weight limits for the exotic rigid carbon forks ?
would I be too heavy to safely use ?
It will be mostly for road use on converting an old hardtail to rigid with slicks.
My current suspension fork is 500mm A2C , I think Ill try get a rigid fork around 465-470 in length
thanks ,
J
support
PostPosted: Fri Feb 28, 2020 1:52 am    Post subject: Rider Weight Limit Reply with quote
Thank you for your message.
Our recommended rider weight limit is 97.5kg (215lbs).
Thank you for your interest and I look forward to serve you soon.
Best Regards
Rebecca
jambonsambo
PostPosted: Mon Mar 02, 2020 2:26 pm    Post subject: Reply with quote
Thanks ,
What about the aluminum forks ? I assume the limit is a lot higher , maybe better for me .
support
PostPosted: Fri Mar 06, 2020 2:34 am    Post subject: Rider Weight Limits for Aluminum Forks Reply with quote
Our manufacturers guarantee for rider weight limit on Aluminium Forks is also 95kg (210lbs).
Thank you for your interest and we look forward to be of service to you soon.
Best Regards
Sui Ping
