I have one of the flat carbon handle bars on my road bike, do you know whether it is advised to use clip on aero bars on the carbon bar. I know it also depends on the torque, any advice would be greatly appreciated.
Thank you Sebastian
by sebastian74 Sun Feb 14, 2021
Hi Sebastian
Thanks for your question.
We would not recommend the use of clip on aero bars with our flat topped carbon road handlebars.
The flat aero edge would not be suitable for the round clamps.
Thanks & Regards
Support
by support Wed Feb 24, 2021
My bike is having a loose handlebar problem. They made me lose my balance and upset the ride, so I figured out How to Fix Loose Handlebars on a Bike. For threaded stems, first, screw the top cap onto the handlebar body. This is followed by loosening the clamp bolts by pulling the stem up and out of the guide tube. After separating the two, a thin layer of lubricant or bicycle grease should be applied, and then the guide tube should be replaced. Also, I think it's a good idea to check the removable headphones if hear any knocking, clacking, or clacking in the front of the bike, as it's very likely that the headphones are also loose.
