Forum
Search Forum
FAQ
Need advice re. correct fork
mirkgrah
PostPosted: Wed May 19, 2021 7:56 am    Post subject: Need advice re. correct fork Reply with quote
Hey there,
I was planning to replace my 10 year old SunTour XCR on my bike with a rigid fork, but I am struggling to find the right fork to fit my bike's geometry and specs:
- 26"
- IS Disc Mount
- Fork length (A-C): 49mm
- Picture here: https://ibb.co/T4TjLYD
The longest 26" fork that I found on your website 46.5cm https://www.carboncycles.cc/index.php?p=499& . Could this fork work for my bike - or would it significantly impact the geometry?
The only fork with the correct length is this https://www.carboncycles.cc/index.php?p=1765&#top - but it is meant for 29" bikes. This fork also comes with a PM disc mount, which isn't ideal because I would need an adaptor.
Would anyone be able to help me find the correct replacement fork?Thank you so much in advance!
PostPosted: Wed May 19, 2021 8:34 am    Post subject: Reply with quote
The fork you suggested is a suitable option. As stated in the 'Geom' Corrected for' column, the fork is ideal to replace a 150mm travel 26" fork, like yours seems to be. Unfortunately, you are correct, the 49cm forks are only available as post mount, so you will need to get an adapter.
Hope that helps.
The CarbonCycles team
mirkgrah
PostPosted: Wed May 19, 2021 9:28 am    Post subject: Reply with quote
Thanks @mikethebike for the quick reply. Just to clarify - you are recommending to get the 49cm 29er (https://www.carboncycles.cc/index.php?p=1765&#top)?
PostPosted: Wed May 19, 2021 9:37 am    Post subject: Reply with quote
This fork is usable for:
26 in: correcting 150mm of travel
650b: correcting130mm, 140mm of travel
29er / 700c: correcting 100mm, 120mm, 130mm of travel
Based on you measuring the length as 49cm as shown in step 6 here (https://www.carboncycles.cc/index.php?s=1&t=0&f=viewtopic.php?p=3820__a__amp;) then this fork should work.
The CarbonCycles Team
mirkgrah
PostPosted: Wed May 19, 2021 9:59 am    Post subject: Reply with quote
Oh I see, thanks for clarifying. I wasn't sure whether there are different versions of the same fork. I just realised though that the fork is unfortunately not available anymore - do you have any idea when it will be back in stock?
PostPosted: Wed May 19, 2021 10:02 am    Post subject: Reply with quote
We will check with the product team and come back to you as soon as we have a reply.
mirkgrah
PostPosted: Wed May 19, 2021 2:59 pm    Post subject: Reply with quote
That would be awesome, thank you Smile
PostPosted: Thu May 20, 2021 5:34 am    Post subject: Reply with quote
We had feedback from the team. The fork is in manufacturing and we expect it to be back in stock end of September/beginning of October.
mirkgrah
PostPosted: Thu May 20, 2021 11:30 am    Post subject: Reply with quote
Hey, thanks for the feedback. Well, I guess I'll have to live with my current fork for a few more months then Wink Just to confirm: there's no alternative fork with the same specs that is currently in stock, or is there (I wasn't able to find an alternative option)?
PostPosted: Fri May 21, 2021 6:43 am    Post subject: Reply with quote
Sorry for the slow reply. Unfortunately, both options that could fit your requirement are not available. Sorry that we can't be more helpful straight away.
Stop In Style Specifications subject to change. © Copyright DiscoBrakes.Com Pte Ltd 1999-2022
