eXotic Monocoque UD Carbon Rigid
I've an old Voodoo Bizango and I'm thinking of replacing the current suspension forks and going rigid, specifically with a set of the 49cm eXotic Monocoque UD Carbon forks.
I've a some questions.
1. What size is the axle
2. As I'd be putting the forks in an alu frame and the forks have a carbon steerer, do I need to use anything like carbon paste?
3. I see you do a carbon compression plug / cap -
https://www.carboncycles.cc/?s=0&c=70&p=637
But it's out of stock. Is there one you'd recommend for use with your forks?
Thanks a lot
by GrimUpNorth     Thu Sep 01, 2022
Thanks for your message. You can get the eXotic Monocoque UD Carbon fork in either a conventional axle (i.e. 100mm spacing and QR) or as a 15mm through axle. With regards to the fitting to an alloy frame, you would not need carbon paste. You can use some on the clamp area of the stem, but you can find some further details here: https://www.carboncycles.cc/index.php?s=1&t=0&f=viewtopic.php?t=4429__a__amp;sid=48090a3e90907e43bce41d0f1d398e32&
We don't have any specific recommendations beyond our own compression device, but we would suggest going for a quality item. There are easily available from various online retailers.
We hope that helps.
Michael
CarbonCycles & DiscoBrakes Team
by Mikethebike     Fri Sep 02, 2022
privacy | terms | blogStop In StyleSpecifications subject to change © Copyright DiscoBrakes.Com Pte Ltd 1999-2025
