DiscoBrakes.Com :: Account :: Search Blog
Get ready for SPRING SALE! *** EXTENDED ***
As SPRING is now officially here - we believe the 20th of March is the official start of the 'pre'-summer season - we have EXTENDED our 'Get ready for SPRING SALE' by another week. So we are going to offer our great savings (up to 50% on selected products) or our 10% on everything discount for another week, in fact, all the way to the 27th of March 2019.
How it works:
From today we are extended our 'Get ready for SPRING SALE' for another week.�We are offering two discount levels. Either the 'up to 50% on selected products' offer or the '10% on everything' discount - all the details can be found below! Please note that the sale will end at midnight on the 27th March 2019, so make sure you get your order in quickly. Please note that you can only use one voucher per purchase. You can purchase (and redeem your discounts) via the www.discobrakes.com or www.carboncycles.cc websites.
Bargain Buckets - up to 50% on selected products:
We have a huge selection of high-quality DiscoBrakes and CarbonCycles products at discounts of up to 50%. Please have a look at our many product groups below. In the headline, you will find the discount level for the product group as well as the code that applies to the products of that group.
To purchase, just select the product you are after and put the correct code into the 'Gift Voucher Code' box at checkout to redeem your discount. If you intend to buy more than one item, then you will have to create separate orders for each item.
10% on everything:
And if you can't find the right product in our 'Bargain Buckets' section, then the 10% off everything discount might make it a bit easier to keep your bike running smoothly into spring. To get your 10% discount, simply log into your account, select the product(s) you are after and use the discount code SPRING10off at checkout, where you are asked to add in your 'Gift Voucher Code'. Simple!
Pedals: 50% off (on products mentioned below) - CODE: 50off_pedals
From top-level alloy pedals with extractable pins to entry-level nylon pedals in a multitude of colours.
eXotic Alloy Flat Pedals - Extruded and CNC machined 6061 Alloy Body - yellow - 430g (CC-PED07F-YEL)
eXotic Thru Pin Alloy Flat Pedals - Extruded and CNC machined 6061 Alloy Body - red - 483g (CC-PED21F-RED)
eXotic Translucent Coloured BMX Pedals - translucent red - 366g (CC-PED24F-RED)
eXotic Solid Coloured BMX Pedals - solid blue - 366g (CC-PED25F-BLU)
eXotic Solid Nylon - Thin and Coloured Nylon Reinforced Pedals � in black, blue, red or white - 370g (CC-PED29F)
Grips: 50% off (on products mentioned below) - CODE: 50off_grips
Hold on tight with our wide range of BMX style grips, as well as selected lock on options.
eXotic Cubik Design - Pair of Grip Cartridges - red - 69g (CC-G10RED)
eXotic Bang Bang BMX Grip - with Flange � in blue, green, grey, red, white or yellow - 128g (CC-G14)
eXotic Lock-on End Caps - Pair of Alloy End Baps � in black, blue, brown, gold, green, grey, orange, pink, purple, red, silver or white - 25g (CC-GC03)
Disc brake pads: 25% off (on products mentioned below) - CODE: 25off_discpads
Find some selected disc brake pads at even lower prices.
DiscoBrakes Hayes El Camino Disc Brake Pads - semi-metallic or sintered (OBE-DH03)
DiscoBrakes Magura Julie Disc Brake Pads - ceramic pro (OBE-DM04CP)
DiscoBrakes RST Disc Brake (DX Mechanical) Disc Brake Pads - sintered (OBE-DR01T)
DiscoBrakes Tektro Io Disc Brake Pads - ceramic pro (OBE-DT01C)
MTB rubber pads: 25% off (on products mentioned below) - CODE: 25off_mtbpads
Get 25% off this broad selection of MTB rubber brake pads and cartridge systems.
DiscoBrakes Forged & CNC'ed Cartridge V-Brake Pads - 72mm � in black, blue, gold, pink, red or silver (OBE-M33N)
DiscoBrakes Fully CNCed V-Brake Shoe Set - 72mm � in black, blue, gold, pink, red or silver (OBE-M59N)
DiscoBrakes Replacements Pads - Brake Light Cartridge Replacement Rubber Pads (OBE-M71R)
DiscoBrakes Cantilever Post brake Pads - 69mm (OBE-MX01)
DiscoBrakes Threaded Post (V-Brake) Pads - 69mm (OBE-MX20)
Road rubber pads: 25% off (on products mentioned below) - CODE: 25off_roadpads
Top performing rubber brake pads for your road bike. Compatible with the main brake systems in the market.
DiscoBrakes Cartridge Road Bike Brake Pads - Compatible with Shimano Road Brake Systems - in black, pink or silver (OBE-R38N)
DiscoBrakes SUPER RECORD Road Bike Brake Pads - Compatible with Campagnolo 11 Speed Road Brake Systems Forged, CNCed Cartridge & Replaceable Pad - 55mm (OBE-R75NR)
Disc brake adapters: 50% off (on products mentioned below) - CODE: 50off_adapter
Find the right adapter for your frame or fork at a bargain price.
DiscoBrakes Front Post Mount to IS Adapter for 160mm / 6 Inch Disc Rotor - For Front Brake - Ti-Gold (OBE-BMS316-TIG)
DiscoBrakes PM to IS Mirror / Reverse Mount Adapter � in 160mm or 180mm (OBE-BMS7)
Bar ends: 50% off (on products mentioned below) - CODE: 50off_barends
Increase the number of hand positions to increase the comfort on long rides as well as give you extra leverage when climbing. We have carbon and alloy versions on offer.
eXotic Carbon Bar Ends - 122g (CC-BR01)
eXotic Alloy Bar Ends - One Piece 6061 T6 Bar Ends - 132g (CC-BR02)
eXotic Short Carbon Bar Ends - Alloy 6061 Clamp - 98g (CC-BR03)
Bottle cages: 50% off (on products mentioned below) - CODE: 50off_cages
Carry your water bottle securely and keep it easily accessible with one of the many carbon bottle cages we have on offer. Super lightweight construction at a SUPER price.
eXotic Full Carbon Bottle Cage - Full Monocoque Design - 24g (CC-BT01)
eXotic X Full Carbon Bottle Cage - 22g (CC-BT02)
eXotic RefleX Bottle Cage - Full Monocoque Design - 20g (CC-BT05)
eXotic Enterprise Bottle Cage - Full Monocoque Design - 29g (CC-BT06)
eXotic 4D Bottle Cage - Full Monocoque Design (CC-BT07)
eXotic eXe Bottle Cage - Full Monocoque Design - 27g (CC-BT08)
Seatposts: 50% off (on products mentioned below) - CODE: 50off_posts
Get yourself a super post upgrade with the latest eXotic carbon posts. Super strong, super lightweight and available in various diameters and lengths.
eXotic Full Carbon Monocoque Seatpost - Tough Full Carbon XC Seatpost - 31.6mm � in 250mm (229g) or 300mm (248g) (CC-S06)
eXotic Carbon Matrix II Seatpost - Carbon Reinforced Seatpost - 31.6mm � in 250mm (161g) or 400mm (205g) (CC-S08)
eXotic Carbon Titanium Seatpost - Carbon Seatpost with Ti Bolts - 30.9mm � in 300mm or 350mm (CC-S203)
Seat clamps: 50% off (on products mentioned below) - CODE: 50off_clamps
Secure and easy to operate seat clamps, including quick release alloy versions as well as a super lightweight carbon option.
eXotic Alloy Seat Clamp - Quick Release Clamp - 40g (CC-C0228)
eXotic Power Wheel Drive Seat Clamp - 100% CNC Machined Body � in 31.8mm (44g) or 34.9mm (47g) (CC-C073)
eXotic Full UD Carbon Seat Clamp - Full UD Carbon with Ti hardware - 34.9mm - 12g (CC-C0834)
Handlebars: 50% off (on products mentioned below) - CODE: 50off_bars
Select your next 'steering' bargain from our wide range of discounted road, mountain bike and BMX bars. Some models are available in various sizes and colours.
eXotic Carbon Matrix Road Bar - 6061 T6 Al Skeleton � in 420mm (295g) or 440mm (295g) (CC-HB11314)
eXotic Full Carbon eXergo Road Compact Bar - Full Carbon Monocoque � in 400mm (228g), 420mm (232g) or 440m (240g) (CC-HB12314)
eXotic Meta II Road Handlebar - Double-butted 6061 T6 - 420mm (CC-HB293142)
eXotic Carbon Matrix Flat MTB Handlebar - 600mm (CC-HF163160)
eXotic Meta Riser Handlebar - double-butted 6061 T6 - 625mm - 248g (CC-HR022562)
eXotic CREATURE BMX Bar - 13 Butted With Standard CrossBar: 8 in Rise 720mm Wide - green (CC-HX25800-GRN)
eXotic CREATURE BMX Bar - 13 Butted With Standard CrossBar: 8.25 in Rise 722mm Wide - black (CC-HX26825-BLK)
eXotic CREATURE BMX Bar - 13 Butted With Standard CrossBar: 8.5 in Rise 722mm Wide - blue (CC-HX27850-BLU)
Stems: 50% off (on products mentioned below) - CODE: 50off_stems
Looking to change your stem length or need some spacers to get your bar and stem position just right?
eXotic Carbon Matrix F Stem 25.4mm Clamp - Carbon Reinforced Stem - 60mm (CC-M132506)
eXotic Meta L Stem Oversize 31.8mm Clamp - 3-D Forged 7050 T73 Al Stem � in 90mm or 100mm (CC-M1631)
eXotic Alloy Spacer for 1 1/8 Inch Fork Steerer Tube - 6061 Alloy - 8mm (CC-P0208)
eXotic Carbon Spacer for 1 1/8 Inch Steerer Tube - Carbon � in 3mm or 5mm (CC-P040)
Road headsets: 50% off (on products mentioned below) - CODE: 50off_headset
Keep your steering on your road bike silky smooth.
eXotic Road Headset 10mm - Carbon Integrated Headset (CC-DR01)
eXotic Road Headset 20mm - Carbon Integrated Headset (CC-DR0120)
Rigid forks: 25% off (on products mentioned below) - CODE: 25off_forks
Our rigid forks cover all sorts of wheel sizes and a wide range of bicycles. We have full carbon, carbon stanchions paired with alloy steerers or full alloy models available.
eXotic Carbon Rigid MTB Fork - Disc Only - Extra long 522mm uncut Steerer - 20in Wheel (CC-F03-20S522)
eXotic CREATURE Carbon BMX Fork - Carbon stanchions - 24in Wheel (CC-F0424)
eXotic JUMP CREATURE Dirt Fork - Strong & Lightweight Carbon Dirt Jump Fork - 26in Wheel (CC-F0505)
eXotic Carbon Rigid 700c Trekking Fork - Carbon Trekking Fork with Disc & V-Brake Mounts for 700c Wheels (CC-F07)
eXotic Rigid Carbon - Stunning Lightweight Carbon Fork - 700c (29er) wheel - 1in Steerer (CC-F0A65-700C)
eXotic Rigid Carbon - Disc Only - Stunning Lightweight Carbon Fork - 700c (650b 29er) Wheel - 1in Steerer (CC-F0B65-700C)
eXotic Rigid Al - Lightweight Alloy fork - 700c (29er) Wheel - 1in Steerer (CC-F0C65-700C)
eXotic XOOK Creature Carbon BMX Fork - Carbon Stanchions - 24in Wheel (CC-F0H24)
eXotic Monocoque UD Carbon Rigid, PM Disc - Single Piece Construction - 26in Wheel � 42.5cm (CC-F0P25)
eXotic Monocoque UD Carbon Rigid, PM Disc - Single Piece Construction - 26in Wheel � 44.5cm (CC-F0P45)
eXotic Sub-Arctic Fat Fork QR15 - eXotic Carbon Fork Tapered Steerer PM - 26in Wheel (CC-F0T468T)
eXotic Sub-Arctic Fat Fork QR15 - eXotic Alloy Fork 1 1/8 inch Steerer PM - 26in Wheel (CC-F0U468)
Jockey wheels and bolts: 50% off (on products mentioned below) - CODE: 50off_jockeybolt
A small yet super affordable selection of jockey wheels and disc brake adapter bolts in a variety of colours.
eXotic CNC Machined Derailleur Pulley - Lightweight Alloy 11 Tooth - pink - 10g per pulley (CC-Y02-PNK)
DiscoBrakes 4 x Alloy M6 Bolts for Adapters - Lightweight Alloy � in black, blue, gold, green or red (OBE-BS09)
Cables 50% off (on products mentioned below) - CODE: 50off_cable
Get some smooth and reliable braking action with your road or mountain bike brake cables as well as brake cable accessories.
DiscoBrakes Complete Brake Cable Set - Reflective - Front & Rear (OBE-BC03V)
DiscoBrakes Mechanical Mountain Brake Cable for Front or Rear - Stainless Steel Teflon Colour Coated � in silver, black, blue, gold, green, orange, pink, red, white and yellow (OBE-BC09)
DiscoBrakes Mechanical Road Brake Cable for Front or Rear - Stainless Steel Teflon Colour Coated � in silver, black, blue, gold, green, orange, pink, red, white or yellow (OBE-BC10)
DiscoBrakes Bendable Anodized Cable Tube 77mm Long - Brake or Gear Cable Compatible - Mechanical Lockout Tube - green (OBE-BCT01-GRN)
DiscoBrakes Cable Adapters - Reduce Cable Stress and Increase Efficiency (OBE-F00002)
If you have any issues or questions, please do not hesitate to contact our support team via:
by Mikethebike     Mon Mar 11, 2019
