DiscoBrakes.Com :: Account :: Login
Spring is coming - get your bike in shape!
Depending on where you live in the world, you probably had to put your bike either into hibernation or the wet and gritty weather has given some of your parts an extra hard time over the winter months. With spring slowly coming through it might be a good idea to check some of the most vital parts of your bike. We at DISCOBRAKES and CARBONCYCLES have these products in stock at extremely competitive prices and manufactured to the highest quality. And here is our checklist:
Check that your brake pads are in tip top condition and that you have plenty of brake compound left for your first few rides in the spring. Check our disc brake pad offering�and our rubber pad offering for road�and MTB.
Equally important�if you run disc brakes is to make sure that your rotors are in good shape. Check for contamination and make sure there is plenty brake surface left. Click here for our broad rotor range.
Super important for effective braking (if you are using cable brakes) and smooth shifting are your cables. We have lots of different variations and colours available. Click here for details.
by Mikethebike     Wed Apr 05, 2017
