May I check if the above-mentioned topic is compatible? I noticed Magura MT5 comes in a single piece which is not I wanted. Does Magura Magura MT7 come with two pieces which requires the brake axle screw to connect both of them? Also, I could not find any pictures for Magura MT7 brake pads.
Hi!
Magura MT5 and MT7 pads are compatible, but it's not usual that MT7 comes with pin screws. If you have a MT5 brake and you want to install MT7 pads, you should buy the screws separately.
