DiscoBrakes.Com :: Account :: Login
SRAM Red AXS road brake pads
I'm running the latest SRAM Red AXS eTap 12 speed group set with their HRD disc brakes on my road bike.
For clarity, A picture of them can be found here: https://www.worldwidecyclery.com/products/sram-red-etap-axs-hrd-disc-brake-caliper-flat-mount-2-piece-polar-grey-d1
I want to upgrade to the ceramic pro brake pads for them as the originals are starting to wear out now and just wondered which pads were the correct ones for my setup?
Many thanks for your help.
by Jabberwocky     Sun Jul 31, 2022
Thanks for your message.
To find the correct pads for your brakes, we would suggest having a look at our pad identifier. You can find the details here: https://www.discobrakes.com/?s=1&t=0&f=viewtopic.php?t=4398__a__amp;
We hope that helps.
DiscoBrakes
by Mikethebike     Mon Aug 01, 2022
Many thanks, looks like they are OBE-DA04 for my setup.
Either way, order placed and now looking forward to better stopping power and less noise Very Happy
by Jabberwocky     Mon Aug 01, 2022
Can the axs group be added with the pads. Normally its the OBE-DA04.
Is it possible to dubbel check this and ad it?
That would be nice for the sram riders Very Happy
Kind regards
by Maximbenoy     Fri Apr 07, 2023
We will look into that and add it listing.
DiscoBrakes
by Mikethebike     Sat Apr 08, 2023
Hi @Maximbenoy,
After looking into this a bit deeper, it appears that multiple pads are used by the HRD disc brakes, depending on being a monoblock or 2 piece caliper. From that point of view, we would strongly recommend using our pad identifier, which will help you to find the right pad for your brake caliper: https://www.discobrakes.com/pdf/DiscoBrakes.Com_Brake_Pad_Identifier_v11.pdf
DiscoBrakes
by Mikethebike     Tue Apr 11, 2023
